TDK MICRO-POL DONGLE 数据手册
TDK µPOLTM Evaluation Boards Summary
Products: FS1406, FS1404, FS1403 and I2C Programming Dongle
Each evaluation board contains a
users design guide for general
operation and specifications for typical
use case, PCB board design, Build of
Materials, schematics, start up and fault
condition test, DC/AC and ripple
performance, efficiency and losses, and
load regulation. Thermal performance
evaluation is also provided.
Three standard evaluation boards
are shown for the FS1406, FS1404
& FS1403 to show a full 10W to 15W
performance rating, respectively --Best Power Module for Current Density
and Performance.
An I2C programming dongle
is optional (shown left).
Only required for I2C
operations.
Highlights
µPOLTM Technology Includes Inductor in a Thermally
Enhanced Package
Small Size 3.3mm x 3.3mm with a height of 1.5mm
Plug & Play (No External Compensation Required)
Digital Communication, I2C Serial Bus
Scalable Output Current, same footprint (3A – 6A)
Adjustable Output Voltage, ±0.5% Initial accuracy
-40°C to 125°C Operating Temperature
Typically used to vary
the Vout +/-5mV step size
over the valid Vout range.
It is provided separately from
the standard evaluation
boards.
TDK µPOL Evaluation Boards
TDK Part Number
Description
Notes
EV1406-1800-A
Standard Eval Board, FS1406, 1.8V, 6A
EV1404-3300-A
Standard Eval Board, FS1404, 3.3V, 4A
EV1403-5000-A
Standard Eval Board, FS1403, 5.0V, 3A
TDK micro-POL Dongle
I2C Programming Board
Optional only need if use I2C
Users Guide
www.tdk.com/POL
under Part No. List
Users Guide
www.tdk.com/POL
under Part No. List
Users Guide
www.tdk.com/POL
under Part No. List
GUI Users Manual
& Software
www.tdk.com/POL
Technical Support
Tools
www.tdk.com/POL
Solution Brief: Power for 5W to 25W
2
DC-DC Power Solutions
TDK Power: 5W to 25W
Best Performance & Current Density
Device Options
3.3mm x 3.3mm x 1.5mm
TM
TDK micro-POL
Power Modules
FS1406-0600
FS1406-0700
FS1406-0750
FS1406-0800
FS1406-0900
FS1406-1000
FS1406-1050
FS1406-1100
FS1406-1200
FS1406-1800
FS1406-2500
FS1404-2500
FS1404-3300
FS1403-3300
FS1403-5000
MOQ
Reel Qty
Voltage
250, 4k 0.6V to 2.5V
250, 4k
0.7V
250, 4k
0.75V
250, 4k
0.8V
250, 4k
0.9V
250, 4k
1.0V
250, 4k
1.05V
250, 4k
1.1V
250, 4k
1.2V
250, 4k
1.8V
250, 4k
2.5V
250, 4k
2.5V
250, 4k
3.3V
250, 4k
3.3V
250, 4k
5.0V
Typical Schematic for FS1406
Current Range
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 6A
1A to 4A
1A to 4A
1A to 3A
1A to 3A
DC-DC + Inductor
FS1406
7.5mm x 8.5mm x 1.5mm
Schematic
3
4
Performance Data
PVIN=7.2V
0.804
PVIN=3.6V
0.802
PVIN=2.1V
0.8
0.798
0.796
0.802
0.8
0.79
2
3
4
5
6
PVIN=3.6V
0.802
PVIN=3.6V
0.8
PVIN=2.1V
PVIN=2.1V
0.794
0.792
1
0.804
0.796
0.792
Output Current(A)
@ -40˚C
PVIN=15V
PVIN=7.2V
0.798
0.794
PVIN=15V
0.804
Output Voltage(V)
Output Voltage(V)
0.806
PVIN=15V
0.806
Output Voltage(V)
0.808
PVIN=7.2V
0.798
0.796
0.794
0.792
2
3
4
5
6
0.79
Output Current(A)
1
2
@ 85˚C
@ 25˚C
Line & Load Regulation
Load Transient 0A to 6A
VO peak-peak = 19mV (±1.2%)
3
4
Output Current(A)
VO ripple = 8mV @ 6A
(±0.51%)
Typical Operating Waveforms
PVin=12.0V, Vo=0.8V, Io=0-6A,
Room Temperature,
No airflow
Io = 6A, 35˚C rise
5
6
TDK MICRO-POL DONGLE 价格&库存
很抱歉,暂时无法提供与“TDK MICRO-POL DONGLE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+918.55500
- 5+863.72000
- 国内价格
- 1+2286.32571
- 3+2191.17980
- 6+2103.44447
- 国内价格 香港价格
- 1+1202.369041+154.89268
